help in picking out new amps
If you're amping speakers, then you use the rms wattage of each for each channel (2 channel or 4 channel).
http://www.onlinecarstereo.com/CarAudio ... ctID=16692
so let me guess get right that amp is perfect for my application so i think so and its 100x4 rms is that 100 rms watts per speaker???
Yes, 100rms x 4 = 100 watts per speaker
the "power handling ratings" on speakers [SEE FAQ SECTION] is nothing but a thermal rating for how much heat (measured in watts) the speaker's coils can handle without physical damage.
This has nothing to do with how much power the speaker needs to reach full output, or excursion.
the power required to drive the speaker is usually considerably less than it's "RMS power handling" spec on the box.
For door speakers and component sets, most times 50-75 watts per channel is all you need from a good, clean amplifier.
^ Also a good thing to keep in mind when setting your gains
I'd stick with running the speakers in the normal fashion... allows for balance... bridging better suited for running mid bass
