Firewall HELP
glowstickgorilla
Firewall HELP
I need to run a 4 Gauge power cable through my firewall - I have an 99' Infiniti I30 - I have not been able to locate any existing punches/holes through my firewall - after looking and looking I am considering drilling through what I believe they call a "clutch plate" my car is automatic there is a diamond shaped piece of plastic on the engine comp & an existing diamond hole through the insullation to the firewall - is this a wise decision - I cannot find anyother way to run this cable - what should I do?
71buickfreak
Make sure that you don't drill through any wires or cables. Also, be sure that you will be able to run the wire in a manner that will clear any pedal mechanisms. this can cause a serious wreck or a fire if something pinches. Also, be sure to use a proper sized hole and add a grommet so you don't get wire chafing and cause a fire.
