Discuss
Discuss
http://caraudioamps.com
A guy called me today about a box. We were talking and he asked if I knew about MegaLoud. He told me the addy and there it is.
Whats your thoughts?
loudwagon15s
We needed a Real Powerhouse to push our Custom Built Inferno Subwoofers and the 3200 Watt Mono Block did not let us down. This amplifier produces 1600rms at 13.8 volts and over 2100rms at 14.4 volts. With the huge power suppliers this amp will easily run two 12" Inferno 3000 watt subs or one 15" 5000 watt Inferno subwoofer. This amplifier has out powered amps in the same price range two to one. Megaloud is very proud of this amp and you will be too.
This Mono Block Has Two Huge Power Supplies!
Only a MegaLoud Amp has a Signal so Clean They are +20dB Higher Than Our Competitors Products.
Nothing Comes Close to The Quality and Craftsmanship in thisPrice Range.
The 1600.1 has out preformed many Manufactures Amplifiers.
"You Simply won't believe your own Ears"
This quote tells me that they are totally full of shit
- MobileAudio219
front page advertises a 6x9", and they recommend capacitors for their products.. that bothers me.
That aside, I looked randomly at their 2 channel 1000W amp, and the specs look really nice.
Good components, although without seeing a board layout, I can't say that with 100% assurance. They use an unregulated power supply (two actually) which I happen to like.. shades of my old Orions.
I'd be willing to play with their amps. Speakers, lolidunno.. maybe.
promising on paper at least
