[img]IM000450.JPG[/img]
This is an amp i just took apart. It's an old Sherwood 100w amplfier. I was wondering what things to look for inside of the amp to see if its blown or not. Anyone that could tell me a few things that i could look for would be helpful. Sorry if the image doesn't come up.
Old Amp
- Chris from Washington
Does it just blow fuses?
Most likely it's the output transistors that are blown.
Do you have a multimeter?
sometimes you can check to see if they are shorted by setting it to continuity setting, and putting a lead on each leg. If it read 0 or short, remove it and test it again. Still says 0, then it's blown.
Now you can replace them, and hope that nothing else has been damaged. Or you can try and test out all the diodes, capacitors, and check for visual damage.
On a Sherwood, I almost wouldn't bother with it.
Or sometimes they are blown apart, cracked or black.
To be quite honest Sherwood is a really crappy brand- right there with Legacy. Not trying to downgarde you or anything, but no sense in dumping $ into something not worth it :)
