I bought an Xtreme amp today for $200. It sounds really great. No clipping or anything.
The question I wanted to ask is about how much power is coming from the amp.
It says
150WRMS x 1 @ 4 ohms.
250WRMS x 1 @ 2 ohms.
500W Max
on the website. http://www.directed.com/coms.asp
The reason I'm asking is that it has two speaker outputs, so there is no bridging involve (that I know of). Is it putting 150W to both my speakers? Or 75W?
There is no clipping. The guy at the car audio place said it would put 230W RMS to both my speakers, Like it says on the box.
"230W RMS x 1 channel @ 4 ohms."
Please help. Thanks a lot.
How many watts is my amp putting out?
Minorthreat412
- Member
Well it cant vary well put out 230 WRMS x1 into 4 Ohms and 150 WRMS x1 into 4 Ohms...
Recheck the booklet/box/amp and get the correct specs.
Minorthreat412
- Member
Minorthreat412
- Member
audiocr381ve
Wow, cant believe you paid $200 for that!
Thats .80$ per watt! ouch!
Take that thing back! Hell I seen an ARC KAR 400.4 for 180 new on CAF...
I think you would have better luck with the new JBL amps, cheaper also.
BTW cant tell you power output unless I know what Ohms your subs are. If they are DVC need to know the final impedance per driver.
