van setup
k0rnyfr33k
van setup
Post by k0rnyfr33k »
ok i have a windstar van how should i setup the system????
what kinda system you looking for?
k0rnyfr33k
loudbass high quilaty
what do you all want to replace? how loud is loud to you? how much of a budget do you have?
k0rnyfr33k
i am replacing all the 5 1/4 speakers both front and back with some component speakers and i already have 2 audiobahn subs with a 2 channel amp
so do you want it louder and sound better then the abahns
k0rnyfr33k
yea what compent speakers should i get and which way should i face the subs im thinkin about gettin somtin like 4 12s of somekind
k0rnyfr33k
what's with the "...." post?
are you really that impatient after only 20 minutes?? lol
for 4 twelves you're talking 8cu ft of box volume (more actually).
I'd suggest considering two 18" subs instead, and using good ones, like two RE SX18 subs. They're about $309 each, so for $620 you're good to go. You'd spend at least that for four 12" subs, and more to amplify all of them well, whereas for two SX18 subs, you can feed them anywhere from 500-1500 watts RMS each and get outstanding results with a vented enclosure.
RE also makes good components, if you want to go with a matched system for speakers. I'd use coaxials in back and separates in front, if it were me, then add a good 4 channel amp at around 75x4 @ 4 ohms to drive them. cross over components at about 100Hz, 12dB slope, and the subs at 50 to 60Hz, 18dB slope.
you'll get great results and teeth-jarring bass
k0rnyfr33k
yea i had to go somewhere....whats the website for re?
