Amplifier Suggestions
- swimmerdude
Right now I have 2 15" Kicker Comp Vr's. It is powered by a 1600w MAX Legacy. I don't know exactly how much watts RMS it puts out but I think its somewhere around 200-250. Now, that is way underpowerd for those subs. I want to find an amp that puts out about 500w RMS x2 or 2 amps that put out 500x RMS. I dont know what OHM the speakers are, sorry. I really dont have a budget but I would prefer not spending over $500-$600. Any suggestions??
well lets figure out what the impedence of the speakers is first....if they are for example 8 ohm then you would want a two channel amp that puts out good bridged power..whereas if they are 4 ohm then you either need a couple of two channel amps, a good bridgeable 4 channel amp, or a two channel amp that is stable at two ohms mono or a monoblock amp......for the price range you are looking at my first suggestion would be an elevation audio xs125.4......399.00
- swimmerdude
dual 2 ohm will either give you 1 ohm or 4 ohm depending on how you wire the voice coils.....i didnt know you could get those dual 2 ohm but im not a kicker dealer.....given this new info and that i reread your first post and see that they are 15's i dont know what is out there in your price range...nothing new maybe someone here has a used amp they can deal on
- swimmerdude
Chris from MI
JBL 1200.1--x2
Stable at 1ohm, can be had off ebay cheap. Even if you do have a real crappy amp, maybe you could rebuild yourself a ported box. That would cost round $30. I’m sure in a well built ported box they would be loud of 600-800 watts. If you’ve already have a good box, look into jbl BP lines, lots of ppl use Hifonics with luck. I think Sinister Audio is a dealer for them, and could get you hooked up.
Audiobass runs a profile amp, and he's had success with that, so if you want just cheap power go that way.
- swimmerdude
