6.5 speakers 2 questions
a32nissan
Post by a32nissan »
Ok so i have a pair of a/d/s 346cs' and , i love them. they are paired to a ppi amp feeding 125 rms to each speaker. so my question is
1. if i BI-Amp them will it get louder as well as clearer.?
:help:
second question is. i know people are not very agreeing with dei, and they're audio stuff.
i was wondering is there a speaker out there louder and clearer?. maybe IDMAX's
Rainbows
ARC
and is it worth the money. or just keep my a/d/s'
A/D/S is still pretty good equipment.
Also what amp are you running?
Bi-Amp? Exactly how is that done?
I'm guessing the speaker has 2 inputs? 1 for the tweeter and 1 for the mid?
So you can run the tweeter off of one amp, and the mid off another?
Is that what you mean?
i would only biamp if you are going active.....otherwise there are probably things like crossover slope and overlap of frequencies and attenutation and what not that some brainy guy designed into the crossover network.
If your passive crossover supports bi-amping, then sure. You can even apply time alignment then. It's probably not worth doing unless you've got more power and/or the time alignment to throw at it, though.
I have an Orion 2500d and that's DEI. I'm happy with it, FWIW.
a32nissan
Post by a32nissan »
yes i meant active set. mid then tweet.
i was wondering if it gets louder when going active.
amp currently is PPI 1000.4
most likely by then xetec P4 evo
No, going active is just another method of crossing over your speakers. Just allows for more processing.
a32nissan
Post by a32nissan »
o, ok Thanks
i just figured since the mid was getting it's own power source that it would be louder
Your passive crossover splits up the total power you send to it between the drivers that are hooked up to it. So if you're not changing the total power, you're not sending anymore to either driver.
Besides, if you're looking to make your stuff louder, power is usually never the way to do it. Unless you're Bill Wolf. ;) On a front stage though, definitely not. More power can help in terms of distortion because you're overtaxing the power supply or other amp components at high levels from transients.
ZeroAccess
Post by ZeroAccess »
Ok for those that are confused as much as I am, I'll translate...
The cow goes MOO....
....hope that helps
