The solution to my car problem
BryanX33
Post by BryanX33 »
Well I found out that it was my battery. Went to wal-mart, bought a new battery for $35. It started up and stayed running, but now I have ANOTHER problem :(
Things in my car no longer work. For example, my clock doesnt work, my power windows dont work, and my heat doesnt turn on. My mom took it for a ride and she said that the heat came on and off, only staying on for about 15 seconds at a time. When I push the buttons to make the windows go down, nothing happens. And my clock just doesnt turn on. Anyone know what could POSSIBLY be wrong NOW? Do I need a stronger battery or something?!? Need responses fast please because this is so annoying. Thanks.
1st did you even take the alt in to have it tested? It may still not be giving you enough juice. And second with all the jump starting you did to that thing... it's a stain on the electrical system so you better start checking all the fuses.
BryanX33
Post by BryanX33 »
The alternator is brand new I know that for sure, and I think im going to bring it to a mechanic tommorow to make sure about it.
swimmerdude
Post by swimmerdude »
If things arent working, check the fuses for them.
BryanX33
Post by BryanX33 »
Yeah im gonna have someone take a look at that for me. Im not experienced wit this shit and I dont wanna end up blowing myself up somehow.
loudwagon15s
Post by loudwagon15s »
humm your into car audio but arent experienced with fuses....time to do some reading? fuses arent exactly complex
Darthness
Post by Darthness »
find fuse box
pull fuse
see if broke. if not broke, put fuse back in
else
if broke, replace broke fuse with a the same size and type
thats the extremely simple version.
- Keith
brtnboarder3241
Post by brtnboarder3241 »
Lol
Darthness wrote:find fuse box
pull fuse
else
^this works... Although I would recommend at least a $1 test light to check the fuses properly, because you won't always be able to visibly see a broken fuse
Hmmm, I see another use for that elusive multimeter. :)
