I got the pleasure of hooking him up with these and I built the box, of course.
These come from Car Godz also!
This is my first experience with Massive Audio. The subs come in a decent box, well packed. Covered in a bag to keep moisture out. The subs look pretty nice with attention to overall detail. The assembly looks to be good.
Im going to let the pictures speak now:
Allen bolt terminals. I swear they are setup for 10 Ga wire! Beware, you will need to fold 14 ga two times at minimum!
Bling bling!
Voice Coil cooling
Sealed box, 1.1 cubes total. Built right to spec. Went with sealed as to port these the box would of approached 2.3 cubes...
Overall decent looking subs. Chris will have to chime in on performance later.
The biggest complaint I have is in there product manual. It calls out the outside diameter of the sub 10 1/2" and the cutout for the sub 9 1/2". This is NOT THE CASE. The sub measures 10 1/8" and the cut out should be no more than 9 3/32".
