When selecting an amplifier for multiple speakers
whataburger
In general what are the rules/ principles of selecting an amplifier for multi subs?
for example: lets say you have 3 4ohm dvc's that are rated at 500rms
if you run them at 2.67 ohms, would you then look for a compatible amplifier that will produce 500 rms @ or around 2.67ohms or would it require an amplifier that can produce 1500 watts @ or around 2.67 ohms?
you would want one that does 1500 at your ohm load, in this case if you have the room it might be more economical to run 4 subs as it will be cheaper to buy a 4th sub than it will be to buy an amp that does 1500 at almost 3 ohms....whereas one that does 2k at 1 ohm is going to be less expensive usually or you could try running at .67 ohms and see if the wire adds enough resistance to get the dc impedence up around 1 ohm and then the amp should be fine because the dc measurement will change while the speaker is playing...but then again there are a lot of amps out there like the audiopipe ap30001d that will do more than that for a decent price, i sell it for 500 and it is a dual mono block that does 3k rms at 2 ohms
- swimmerdude
Not neccessarily Bill... I know that the Memphis Amps were completely capable of handling 3 subs at that configuration... In fact i know a friend of mine was running 3 Infinity Kappa Perfects 12" on a Memphis 1500w amp... Killer Sound System in that lil shit box he had lol
COR UNUM VIA UNA - Jay Chmura
breakjunki
whataburger
