serious doubleouble dooble dbzzzzzzzzzzzzzzzz
4 volfenhaag 6x9's.....popped the rear window out of the car and threw it back 4 ft. onto the garage floor.....thats all im sayin
kevinberry1
Robert Wollenberg
You probably used that trick where you just lay them all on the back deck without any sort of box or anything, and use their magnets to hold them in place, unleashing the raw power from both sides of the speaker. Yeah, that's an old trick. Nice try though. I'm not impressed. lol
Robert R. Wollenberg
Audio Alchemy, Owner
Phone: (325) 480-2790
E-mail: [email protected]
Web: www.audiochemy.com
www.abilenecaraudio.com
www.abilenecaralarms.com
i was runnin em off the factory cd player, wired at .0125 ohm nominal......so if my head unit is 50 per channel at 4 ohms and 100 at 2 ohms, then at 1 ohm its 200 and at .5 ohm its 400 per channel then at .25 ohm its 800 per channel so at .0125 its 800 per channel......thats 1600 watts rms to my rear speakers....100% efficiency too cause my head lights dont dim or nothing
and dude when you got that kinda power you cant let the magnets hold em in place, theyll come loose and brain you....you got to use 3" lag bolts and weld the nuts on the end of them.....
loudwagon15s
is that even possible or am i just EXTREMELY gulliblesmoker wrote:i was runnin em off the factory cd player, wired at .0125 ohm nominal......so if my head unit is 50 per channel at 4 ohms and 100 at 2 ohms, then at 1 ohm its 200 and at .5 ohm its 400 per channel then at .25 ohm its 800 per channel so at .0125 its 800 per channel......thats 1600 watts rms to my rear speakers....100% efficiency too cause my head lights dont dim or nothing
OMG... Some of the stuff Terry comes up with makes me laugh so frigg'n hard
