my crossover is built into my kicker 650.4 amp.smoker wrote:you probably have a tweeter adjustment on your crossover....it may be set at 0 db if you have the option try it at -3 db or so.....
quote from the specs:
variable front and rear high-/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
